Today, we are pleased to release v3.2.003 to Early Access Program participants This contains over 200 bug fixes and enhancements (mostly to individual vehicle support modules). A summary of the major changes is here:
2019-09-17 MWJ  3.2.003  OTA release
- New vehicle: Renault Zoe (adaption by Marcos Mezo <mmezo@selexco.net>)
- Module: task CPU usage statistics & debug records
- Server V2: restart network on RX connection loss (issue #241 workaround)
- Network: avoid using wifi networks with too bad signal quality
- Network: provide dedicated metrics for modem & wifi channel states
- Regen brake signal: added power base range, power smoothing & foot brake config
- Twizy: added tuning option for SEVCON_T45 + Gearbox_T80 hybrid
- Twizy: OBD2 VIN reading & cluster DTC monitoring
- New vehicle: Smart ED/EQ 4.Generation (453) (adaption by Thomas Heuer <egon@heuer-humfeld.de>)
- Locations: Introduce support for location actions
- Twizy: Release 1.0.0 -- all V2 features planned are now included in V3
- Vehicle framework: DBC and RETOOLS integrations
- Vehicles: Extensions to Kia Niro, Kia Soul, Mitsubishi, Nissan Leaf,
  Renault Twizy, SmartID, Tesla Model S, and Think City
For full detail on all changes, check the GitHub revision history. The v3 modules can be updated over the air (wifi), via SD CARD, or over USB - all without requiring special hardware programmers like the PICKIT used for v2. The simplest way to update the module firmware is to connect it as a client to your wifi network (or phone hotspot), and then use the web interface Config / Firmware / Flash-from-Web; that will show you the version you are running, as well as the latest version available for update. One click on 'Flash now' and the update will be downloaded and installed. Alternatively, you can download the firmware update to a file named ovms3.bin in the root directory of a FAT formatted SD CARD and insert the card into the module's slot - the new firmware will be updated automatically and the file renamed ovms3.done to signify completion. This firmware also includes the feature to check for and automatically update to newly available firmware, every night (so long as the vehicle is connected to WiFi). After updating to 3.1.005 or later, you can enable this for future firmware releases with 'config ota auto yes'. You can choose the release level by setting 'config ota tag edge | eap | main', as one of:
  • edge: Bleeding edge developer nightly-builds
  • eap: Early Access Program (full releases, but with little public testing)
  • main: Publicly tested full releases (the most stable)
Thank you to all the open source developers who have contributed to this, and previous, releases, and thank you for your support of the project. Open Vehicles
