3 posts / 0 new
Paul Wolstenholme
Leaf 2016 AZE0-2 charge stop not working
The installation instructions for this model (2016 AZE0-2) do NOT request the disconnection of the TCU like they do for the earlier and later versions (it notes it is on the CAR CAN bus).  Is this deliberate or a misinterpretation of the authors' intent?  I have neither attempted disconnection of the TCU nor have I disabled its output.
I have had intermittent problems with the OVMS failing to lock / unlock / start charging / stop charging for the 3 years I've been using it.  We haven't been using the remote climate control feature so I will not comment on that.  This failure mode can occur...
1. when using the Android app
2. when using the the web interface
3. after setting the OVMS to stop charging at a specified SoC (I usually set this to 81%) and the SoC being reached.  This is of most concern to me as it it why I got the OVMS.  There is no other simple way of preventing charging from running to 100% SoC.
These features (i,e, OVMS commanding the car) work sometimes but then inexplicably stop working even when tried repeatedly.  They have tended to work again after unplugging the OVMS for a short while, or maybe after rebooting it.  Since the app was updated recently I have no longer had success at getting the OVMS to successfully "stop charging" by any method.
Is it possible that this behaviour is the result of a conflict with the TCU?
Paul Wolstenholme
Leaf AZE0-2
Does anybody else have an OVMS fitted to a Nissan Leaf AZE0-2?
andyorkney
andyorkney's picture
Hi Paul, I'm new to OVMS so
Hi Paul, I'm new to OVMS so very far from expert, it's been a steep learning curve. I had very similar issues (might yet repeat) but I found that installing the "OVMS connect" app and switching v3 server has helped. Also you say that you are not using remote climate; this can be THE point of issue. When our 2018 env200 does not respond, activating climate is the almost sure fire way to wake the car and then the other activations will work.
At moment I'm trying to write script for start / stop charge of the car (without reliable success so far...) and hope to create custom button commands for 80% and 100% charging options. Still not 100% convinced I have the car set up with best parameters for reliable function but slowly getting there - of course you have a different car so you experience will vary.
