3 posts / 0 new
Fenixan
The most stable firmware version
I've been using OVMS for about 4 months now. I've tried many firmwares, but so far "3.3.005-1-geed58d6f" is probably the best. However, it's not perfect, it restarts two or three times a day and sometimes it freezes so much that only removing the battery helps.
What is your experience? Which version should I use?
I have a 2018 40kwh ZE1.
Thanks
umbjm
I have a 2015 24kwh US Leaf S
I have a 2015 24kwh US Leaf S. I don't see this firmware version in the web interface, just one from 2022:  3.3.003/ota_1/main (build idf v3.3.4-848-g1ff5e24b1 Sep 1 2022 08:40:30)
Under that, "Available" only shows 3.3.003. Is there some other way?
Update: I did the web update through the web interface. All went well according to the window. I restarted but nothing had changed. What am I missing?
JBob
If you did the web update you
If you did the web update you will find that there will be the different versions of the firmware stored on the OVMS but it will be set to boot from the original one. You have to tell it do boot from the new one via the web interface.
I noticed mine was always booting from the original firmware even though I thought I'd updated it. I eventually found this "boot from" setting.
