4 posts / 0 new
Marcus85
OVMS random crash (daily)
Hi,
I have an VW eUP and the module is installed via ODB. It is working but I recognized, that the module is crahsing almost every day.
Some times I have to restart it manually (disconnect --> connect).
I see the following error:
Last boot was 8996 second(s) ago
Time at boot: 2026-06-20 06:46:21 CEST
This is reset #4 since last power cycle
Detected boot reason: Crash (12/12)
Reset reason: Exception/panic (4)
Crash counters: 4 total, 0 early
Last crash: LoadStoreAlignment exception on core 1
Registers:
PC : 0x4008f3fe PS : 0x00060a33 A0 : 0x800911bf A1 : 0x3ffc8c50
A2 : 0x687373af A3 : 0x00060a20 A4 : 0x00000001 A5 : 0x0000abab
A6 : 0xb33fffff A7 : 0x00000000 A8 : 0x0000cdcd A9 : 0x3ffc8c50
A10 : 0x0000abab A11 : 0x00060a23 A12 : 0x00060a20 A13 : 0x00000001
A14 : 0x000000fe A15 : 0x00000000 SAR : 0x00000001 EXCCAUSE: 0x00000009
EXCVADDR: 0x687373af LBEG : 0x400029ac LEND : 0x400029cb LCOUNT : 0x00000000
Current task on core 0: IDLE0, 516 stack bytes free
Current task on core 1: OVMS Events, 4404 stack bytes free
Backtrace:
0x4008f3fe 0x400911bc 0x40084ba5 0x40084bc2 0x40133c2d 0x40133cd8 0x401369e4 0x4016dad1 0x4016fc40 0x40172116 0x4016d5b2 0x4012255e 0x40122979 0x40122d68 0x40122ded
Event: ticker.1@ovms-server-v2 0 secs
Version: 3.3.005-3-g4f3f7688/ota_0/main (build idf v3.3.4-851-gfa4f07fb3b Sep 7 2025 08:02:51)
Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
Firmware: 3.3.005-3-g4f3f7688/ota_0/main (build idf v3.3.4-851-gfa4f07fb3b Sep 7 2025 08:02:51)
Running partition: ota_0
Boot partition: ota_0
Factory image: 3.3.005-842-g30dba204
OTA_O image: 3.3.005-3-g4f3f7688
Last boot was 97045 second(s) ago
Time at boot: 2026-06-20 06:46:24 CEST
Registers:
Backtrace:
Can you help me? Thank you in advance!!
markwj
markwj's picture
It is crashing in ticker 1.
Do you have any scripts running (javascript, or shell)? If not, then best to post the module summary and we can check.
markwj
markwj's picture
Note also that this seems
Note also that this seems wierd:
Your ota_0 image is 3.3.005-3, but the factory image is much newer (3.3.005-842). However, you are running from ota_0?
Marcus85
Hey,
Hey,
Thanks for your answer!
I updated the firmware and partition now. I hope it was correct :)
Last boot was 101 second(s) ago Time at boot: 2026-06-29 23:50:25 CEST This is reset #4 since last power cycle Detected boot reason: SoftReset (12/12) Reset reason: esp_restart (3) Crash counters: 0 total, 0 early Auto init level: Full
Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600 Firmware: 3.3.006-123-gd26cb4392/ota_0/main (build idf v3.3.4-854-g9063c8662c Jun 25 2026 23:02:06, product v3.3-5) Partition type: v3-35 (ota1, ota2, no factory, maximized store) Partition table: 0x8000 Running partition: ota_0 Boot partition: ota_0 OTA_O image: 3.3.006-123-gd26cb4392
I have to wait and see if the OVMS will still crash. I will keep you informed in a few days :)
