6 posts / 0 new
jbeuree
OVMS Keeps trying to charge over and over
Have a newly installed OVMS, and for some reason it caused the car to continually keep charging all night over and over. Used the OVMS to initiate the initial charge as it was on the timer, so it wasn't going on it's own initially. It kept going all night though, and the logs look like the OVMS was trying to initiate a new charging session every time the previous one completed. Had to unplug the vehicle to get it to stop. Here's a sample of what kept showing up in the logs. Any advice on what the possible cause of this would be?
2020-08-24 01:37:57 EDT I (12333553) ovms-server-v2: Incoming Msg: MP-0 AFA
2020-08-24 01:37:57 EDT I (12333553) ovms-server-v2: Send MP-0 a
2020-08-24 01:38:19 EDT I (12355163) ovms-server-v2: Send MP-0 PA - Charge Stopped|SOC: 100.0%|Ideal range: 160km|Est. range: 112km|ODO: 121494.0km|CAC: 52.8Ah|SOH: 80%
2020-08-24 01:38:19 EDT I (12355653) pushover: Sending message Charge starting with priority -2
2020-08-24 01:38:24 EDT I (12360363) pushover: PushoverMongooseCallback(MG_EV_CONNECT=0:Success)
2020-08-24 01:38:24 EDT I (12360393) ovms-server-v2: Send MP-0 PI - Charging|396.0V/0.0A|SOC: 98.0%|Ideal range: 160km|Est. range: 112km|ODO: 121494.0km|CAC: 52.8Ah|SOH: 80%
2020-08-24 01:52:59 EDT I (13235493) ovms-server-v2: Incoming Msg: MP-0 AFA
2020-08-24 01:52:59 EDT I (13235493) ovms-server-v2: Send MP-0 a
2020-08-24 01:57:25 EDT I (13501243) housekeeping: 2020-08-24 01:57:25 EDT (RAM: 8b=80672-84060 32b=9576)
2020-08-24 01:59:45 EDT I (13641163) ovms-server-v2: Send MP-0 PA - Charge Stopped|SOC: 100.0%|Ideal range: 160km|Est. range: 113km|ODO: 121494.0km|CAC: 52.8Ah|SOH: 80%
2020-08-24 01:59:45 EDT I (13641183) pushover: Sending message Charge starting with priority -2
2020-08-24 01:59:48 EDT I (13644923) pushover: PushoverMongooseCallback(MG_EV_CONNECT=0:Success)
Drc38
Hi, I have not used the timer
Hi, I have not used the timer or charge start feature through ovms myself. If you let me know what build version you're running and age/battery size of your Leaf I can see if I spot anything in the code that may cause the issue for you.
Just a thought, as it appears the start charge message is coming from the App, do you slide it across once and slide back to the start the charge? Or leave it slid across?
Cheers Derek
jbeuree
I'm on the latest build, 3.2
I'm on the latest build, 3.2.0.14. It's a 2015 SV model, with the 24kwh battery. I slid the charge indicator in the app (android) to the right to start the charge, and think I also tried to see what would happen by sliding it back, but it didn't appear to do anything. I'll try some different combinations, including not using the app at all, to try to isolate the exact cause.
markwj
markwj's picture
I suggest look at the logs
I suggest look at the logs (in debug or verbose mode) a little before what you show, to see if you can find out what initiated the charge. The logs you show are just the charge itself starting, not who/what requested that.
jbeuree
Ok, thanks for the suggestion
Ok, thanks for the suggestion. I was most concerned that this could happen all the time and wreck the battery, but I've done 2 charges since and they both worked normally, although the events look a little messed up to me (i.e. charge start and stop when plugging in but not charging, only a charge stop at the end and no charge finished). I'll try different variations each day to narrow down the cause and then crank up the logs to try to figure out why.
jbeuree
Whatever is causing the car
Whatever is causing the car to charge over and over happens very infrequently, but did happen again last night. We've had this vehicle 6 years, and it never did this before plugging in the ovms. I turned on logging and let it go through a cycle where it finished and started again on it's own, but don't see anything obvious in the logs. Is it possible the ovms is somehow interfering with the car's own communications and causing this to happen? Wondering what the best way to debug this would be. Maybe turn off can writes, if that's supported on the leaf?
Also, I do use the leaf's charge timer, which seems to still work fine with the ovms. In the case of last night, it was plugged in before the charge timer should have been in effect but looks like it started charging right away. Don't have logs from it being first plugged in but here's what a bit from it finishing charging and restarting:
2020-10-03 07:04:38 EDT V (70041238) v-nissanleaf: Range: ideal=112 km, est=94 km, full=94 km
2020-10-03 07:04:38 EDT V (70041238) v-nissanleaf: Time remaining: 0 mins to full
2020-10-03 07:04:38 EDT D (70041238) v-nissanleaf: Poll state: 3
2020-10-03 07:04:39 EDT V (70041718) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=5c, LEN=79)
2020-10-03 07:04:39 EDT V (70041728) gsm-nmea: IncomingLine: $GNGNS,110439.0,4514.850943,N,07555.324123,W,AA,11,0.8,142.1,-36.0,,*52
2020-10-03 07:04:39 EDT V (70041728) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
2020-10-03 07:04:39 EDT V (70041728) gsm-nmea: IncomingLine: $GPRMC,110439.0,A,4514.850943,N,07555.324123,W,0.0,191.3,031020,,,A*78
2020-10-03 07:04:39 EDT D (70041728) time: gsm-nmea (stratum 2 trusted 1) provides time Sat Oct  3 11:04:39 2020 (000000us) UTC
2020-10-03 07:04:40 EDT V (70042728) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=5c, LEN=79)
2020-10-03 07:04:40 EDT V (70042728) gsm-nmea: IncomingLine: $GNGNS,110440.0,4514.850939,N,07555.324121,W,AA,11,0.8,142.1,-36.0,,*53
2020-10-03 07:04:40 EDT V (70042728) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
2020-10-03 07:04:40 EDT V (70042728) gsm-nmea: IncomingLine: $GPRMC,110440.0,A,4514.850939,N,07555.324121,W,0.0,191.3,031020,,,A*79
2020-10-03 07:04:40 EDT D (70042728) time: gsm-nmea (stratum 2 trusted 1) provides time Sat Oct  3 11:04:40 2020 (000000us) UTC
2020-10-03 07:04:41 EDT V (70043758) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=5c, LEN=79)
2020-10-03 07:04:41 EDT V (70043758) gsm-nmea: IncomingLine: $GNGNS,110441.0,4514.850937,N,07555.324121,W,AA,11,0.8,142.1,-36.0,,*5C
2020-10-03 07:04:41 EDT V (70043768) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
2020-10-03 07:04:41 EDT V (70043778) gsm-nmea: IncomingLine: $GPRMC,110441.0,A,4514.850937,N,07555.324121,W,0.0,191.3,031020,,,A*76
2020-10-03 07:04:41 EDT D (70043778) time: gsm-nmea (stratum 2 trusted 1) provides time Sat Oct  3 11:04:41 2020 (000000us) UTC
2020-10-03 07:04:42 EDT D (70044768) events: Signal(vehicle.charge.stop)
2020-10-03 07:04:42 EDT D (70044768) pushover: EventListener: Handling event (vehicle.charge.stop)
2020-10-03 07:04:42 EDT I (70044778) pushover: Sending message Charge has stopped with priority -1
2020-10-03 07:04:42 EDT V (70044778) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=5c, LEN=79)
2020-10-03 07:04:42 EDT V (70044788) gsm-nmea: IncomingLine: $GNGNS,110442.0,4514.850936,N,07555.324122,W,AA,11,0.8,142.1,-36.0,,*5D
2020-10-03 07:04:42 EDT V (70044788) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
2020-10-03 07:04:42 EDT V (70044788) gsm-nmea: IncomingLine: $GPRMC,110442.0,A,4514.850936,N,07555.324122,W,0.0,191.3,031020,,,A*77
2020-10-03 07:04:42 EDT D (70044798) time: gsm-nmea (stratum 2 trusted 1) provides time Sat Oct  3 11:04:42 2020 (000000us) UTC
2020-10-03 07:04:42 EDT V (70044858) pushover: Msg: POST /1/messages.json HTTP/1.1||Host: api.pushover.net||Connection: close||Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8||Content-Length: 141||||token=af1jtp1xwum3ju1bc5nxdz88dhi23g&user=ups2nskoxvsvegpgmgvgwfjytjq3gs&message=Charge has stopped&priority=-1&title=2015LeafSV-1N4AZ&sound=
2020-10-03 07:04:42 EDT D (70044878) events: Signal(vehicle.charge.state)
2020-10-03 07:04:42 EDT D (70044878) pushover: EventListener: Handling event (vehicle.charge.state)
2020-10-03 07:04:42 EDT D (70044888) pushover: EventListener: No priority set -> ignore notification
2020-10-03 07:04:42 EDT D (70044888) events: Signal(vehicle.charge.mode)
2020-10-03 07:04:42 EDT D (70044888) pushover: EventListener: Handling event (vehicle.charge.mode)
2020-10-03 07:04:42 EDT D (70044908) pushover: EventListener: No priority set -> ignore notification
2020-10-03 07:04:42 EDT V (70045238) simcom: tx: f9 0d ff 3b 41 54 2b 43 52 45 47 3f 3b 2b 43 43 | ...;AT+CREG?;+CC
2020-10-03 07:04:42 EDT V (70045238) simcom: tx: 4c 4b 3f 3b 2b 43 53 51 3b 2b 43 4f 50 53 3f 0d | LK?;+CSQ;+COPS?.
2020-10-03 07:04:42 EDT V (70045238) simcom: tx: 0a cf f9                                        | ...
2020-10-03 07:04:42 EDT V (70045258) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=69, LEN=111)
2020-10-03 07:04:42 EDT D (70045258) simcom: rx line ch=3 len=10  : +CREG: 1,5
2020-10-03 07:04:42 EDT D (70045268) simcom: rx line ch=3 len=29  : +CCLK: "20/10/03,07:04:38-16"
2020-10-03 07:04:42 EDT D (70045268) simcom: rx line ch=3 len=11  : +CSQ: 20,99
2020-10-03 07:04:42 EDT D (70045268) simcom: rx line ch=3 len=33  : +COPS: 0,0,"VIDEOTRON Hologram",2
2020-10-03 07:04:42 EDT D (70045268) simcom: rx line ch=3 len=2   : OK
2020-10-03 07:04:42 EDT V (70045718) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=5c, LEN=79)
2020-10-03 07:04:43 EDT V (70045718) gsm-nmea: IncomingLine: $GNGNS,110443.0,4514.850936,N,07555.324122,W,AA,11,0.8,142.1,-36.0,,*5C
2020-10-03 07:04:43 EDT V (70045728) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
2020-10-03 07:04:43 EDT V (70045728) gsm-nmea: IncomingLine: $GPRMC,110443.0,A,4514.850936,N,07555.324122,W,0.0,191.3,031020,,,A*76
2020-10-03 07:04:43 EDT D (70045728) time: gsm-nmea (stratum 2 trusted 1) provides time Sat Oct  3 11:04:43 2020 (000000us) UTC
2020-10-03 07:04:50 EDT V (70046718) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=5c, LEN=79)
2020-10-03 07:04:50 EDT V (70046718) gsm-nmea: IncomingLine: $GNGNS,110444.0,4514.850933,N,07555.324122,W,AA,11,0.8,142.1,-36.0,,*5E
2020-10-03 07:04:50 EDT V (70046728) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
2020-10-03 07:04:50 EDT V (70046728) gsm-nmea: IncomingLine: $GPRMC,110444.0,A,4514.850933,N,07555.324122,W,0.0,191.3,031020,,,A*74
2020-10-03 07:04:50 EDT D (70046728) time: gsm-nmea (stratum 2 trusted 1) provides time Sat Oct  3 11:04:44 2020 (000000us) UTC
2020-10-03 07:04:50 EDT D (70047678) events: Signal(vehicle.charge.start)
2020-10-03 07:04:50 EDT D (70047678) pushover: EventListener: Handling event (vehicle.charge.start)
2020-10-03 07:04:50 EDT D (70047688) pushover: EventListener: No priority set -> ignore notification
2020-10-03 07:04:50 EDT D (70047698) events: Signal(vehicle.charge.mode)
2020-10-03 07:04:50 EDT D (70047698) pushover: EventListener: Handling event (vehicle.charge.mode)
2020-10-03 07:04:50 EDT D (70047718) pushover: EventListener: No priority set -> ignore notification
2020-10-03 07:04:50 EDT V (70047728) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=5c, LEN=79)
2020-10-03 07:04:50 EDT V (70047728) gsm-nmea: IncomingLine: $GNGNS,110445.0,4514.850931,N,07555.324122,W,AA,12,0.8,142.1,-36.0,,*5E
2020-10-03 07:04:50 EDT V (70047738) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
2020-10-03 07:04:50 EDT V (70047738) gsm-nmea: IncomingLine: $GPRMC,110445.0,A,4514.850931,N,07555.324122,W,0.0,191.3,031020,,,A*77
2020-10-03 07:04:50 EDT D (70047738) time: gsm-nmea (stratum 2 trusted 1) provides time Sat Oct  3 11:04:45 2020 (000000us) UTC
2020-10-03 07:04:50 EDT D (70047738) events: Signal(vehicle.charge.state)
2020-10-03 07:04:50 EDT D (70047748) pushover: EventListener: Handling event (vehicle.charge.state)
2020-10-03 07:04:50 EDT D (70047748) pushover: EventListener: No priority set -> ignore notification
2020-10-03 07:04:50 EDT V (70048728) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=5c, LEN=79)
2020-10-03 07:04:50 EDT V (70048738) gsm-nmea: IncomingLine: $GNGNS,110446.0,4514.850931,N,07555.324123,W,AA,12,0.8,142.1,-36.0,,*5C
2020-10-03 07:04:50 EDT V (70048738) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
2020-10-03 07:04:50 EDT V (70048738) gsm-nmea: IncomingLine: $GPRMC,110446.0,A,4514.850931,N,07555.324123,W,0.0,191.3,031020,,,A*75
2020-10-03 07:04:50 EDT D (70048738) time: gsm-nmea (stratum 2 trusted 1) provides time Sat Oct  3 11:04:46 2020 (000000us) UTC
2020-10-03 07:04:50 EDT V (70049728) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=5c, LEN=79)
2020-10-03 07:04:50 EDT V (70049728) gsm-nmea: IncomingLine: $GNGNS,110447.0,4514.850933,N,07555.324124,W,AA,12,0.8,142.1,-36.0,,*58
2020-10-03 07:04:50 EDT V (70049728) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
2020-10-03 07:04:50 EDT V (70049738) gsm-nmea: IncomingLine: $GPRMC,110447.0,A,4514.850933,N,07555.324124,W,0.0,191.3,031020,,,A*71
2020-10-03 07:04:50 EDT D (70049738) time: gsm-nmea (stratum 2 trusted 1) provides time Sat Oct  3 11:04:47 2020 (000000us) UTC
2020-10-03 07:04:50 EDT V (70050728) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=5c, LEN=79)
2020-10-03 07:04:50 EDT V (70050738) gsm-nmea: IncomingLine: $GNGNS,110448.0,4514.850935,N,07555.324126,W,AA,12,0.8,142.1,-36.0,,*53
2020-10-03 07:04:50 EDT V (70050738) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
2020-10-03 07:04:50 EDT V (70050738) gsm-nmea: IncomingLine: $GPRMC,110448.0,A,4514.850935,N,07555.324126,W,0.0,191.3,031020,,,A*7A
2020-10-03 07:04:50 EDT D (70050738) time: gsm-nmea (stratum 2 trusted 1) provides time Sat Oct  3 11:04:48 2020 (000000us) UTC
2020-10-03 07:04:50 EDT V (70051238) v-nissanleaf: Range: ideal=110 km, est=92 km, full=94 km
2020-10-03 07:04:50 EDT D (70051238) v-nissanleaf: Poll state: 3
