3 posts / 0 new
nikwest
My OVMSv1 module doesn't connect anymore
I have been using OVMSv1 for many years without issues. Now I cannot get it to work anymore for many months.Not sure if something on the server side changed or if the module is actually broken. Any ideas howto debug this?
Thanks
Dominik
nikwest
Ok, I answering my own
Ok, I'm answering my own question. The IP of www.openvehicles.com seemed to have changed. Now I'm wondering if I should better use ovms.dexters-web.de as I'm located in Germany? But this requires reregistering there, I guess.
markwj
markwj's picture
If you use DNS (8.8.8.8) then
If you use DNS (8.8.8.8) then you can simply use api.openvehicles.com and that will avoid having to use IP address.
