6 posts / 0 new
alayton13
Modem is running but PPP not connected Last Error: User Interrupt
Think I must have done something wrong during setup and now get this message
Anyone know what this means and where can I go to fix this?
Or do I have to reset and start again?
markwj
markwj's picture
It means the cellular data
It means the cellular data connection could not be established. Or you using the defautl Hologram SIM and have you activitated that on Hologram? Is the GSM antenna connected, and are you in range of a cellular tower? If not using Hologram, you will need to set the cellular APN, User, and Password, correctly for your cellular provider.
hdinnc
hdinnc's picture
PPP not connected
State: NetWait
PPP: NOT CONNECTED
last error:  User Interrupt
Anyone know what this means. I have retried three times.
hdinnc
hdinnc's picture
PPP not connected
State: NetWait
PPP: NOT CONNECTED
roussir
Weak signal?
My guess would be weak signal. Try to find a better location for the antenna. I had to bring mine to the window and hold it up to pick up a signal.
markwj
markwj's picture
It means the cellular network
It means the cellular network data connection was lost (most likely due to weak connection).
