2 posts / 0 new
jdanders
Module pp3 has 0.0.0.0 IP address and doesn't connect to cell network
I've noticed my LEAF will occasionally get into a state where things work just fine on Wifi, but once the car leaves Wifi I lose ability to communicate with it. At least a couple of times when I've taken a look at things while in this state, I've noticed that the pp3 interface is messed up.
OVMS# network status
Interface#3: pp3 (ifup=1 linkup=0)
  IPv4: 0.0.0.0/255.255.255.255 gateway 0.0.0.0
MODEM Status
Model: SIM7600
Network Registration: NotRegistered
Provider: T-Mobile Hologram
Signal: -71 dBm
Mode: LTE,Online
State: NetWait
Mux: Status up
PPP: Not connected
Last Error: User Interrupt
GPS: Connected on channel: #1
So the interface is up, but it does not have a valid IP address. From Hologram webpage, it says:
Ready Status
This device is activate and has access to the Hologram network. It is not currently tranmitting data.
If I manually stop and start the Cellular Modem, I get a valid IP address, linkup=1, Network Registration=RegisteredRoaming, State=NetMode, PPP=Connected. Also, Hologram status goes form "Ready" to "Connected."
Is there any code to detect this case and restart the Cellular Modem?
If not, can I get a pointer to where in the code this could be added? I'm willing to take a look.
dexter
dexter's picture
The code to detect this case is here…
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/ovms_cellular/src/ovms_cellular.cpp#L1060
…assuming it was a PPP disconnect, which you should assert first by enabling logging and analyzing the next occurrence.
