Hi there.
I have installed OVMS on my Nissan Leaf from 2016. It works great. There is only one issue: I can't set a max SOC when charging from the app. I can do it from the webinterface and that works fine, but I would like to be able to control it from the app. The only info I get is a brief OVMS 203 Unsupported Operation message, when I access the charging interface on the app.
I can lock/unlock, start/stop charging etc fine from the app.
Anybody know what the issue is or how I go about troubleshooting it?
Thanks!
I remember having a problem with this when the new interface was launched.
I just went back to the old interface, which I prefer. In any case, though I probably didn't give the new enough of a chance.
On this interface you can set the Sufficient SOC in the features panel. For me this works without an issue. If you don't mind the old interface that might be a solution for you.
Thank you for the suggestion. Unfortunately reverting to the old interfaced just crashes my app.
