4 posts / 0 new
PaulC
Missing functionality
Hi all.
I am hoping there is someone who can assist me in the setup of OVMS on my e-nv200 camper van .
First, some background: The van is an 2020 e-nv200 40kWh, 2020 Tekna. I am the second owner and the van builder, for the first owner, "upgraded" the navigation unit to a Panasonic head unit with the capability for Android Auto. The main reason for this swap was to enable the new user a larger screen display for use when reversing. I would have gone about this in a very different way, but nevertheless this is what I have.
When I bought the van I had no idea what impact the removal of the original navigation system had on many other systems on the van. I now have no way of even setting the clock, setting the charge timer or the cabin preheat functions. With assistance from others on various forums, I was recommended to fit an OVMS system, which should get me back all of the missing functionality as this unit interfaces directly with the van's Canbus.
The OVMS system is now installed and I have disconnected the telematics unit, but I am now struggling with certain aspects and this is the nature of my request.
Things that initially do not seem to work are: TPMS system, which does not show on the "Car" tab. I'm not sure whether I would expect these to show there at the moment in any case, as the vehicle dashboard only displays pressures once in motion and perhaps that is an expectation that I shouldn't have?
Waking up the vehicle. This causes a relays to click in the dashboard and no other functionality as far as I can see.
The aircon cannot be turned on or off. If I select it, it gives a message that it is turning on and subsequently says that it was okay, but nothing happens. Same with locking and unlocking the vehicle. If I turn the aircon on or off manually. The status is immediately reflected in the app, but I have no control. Canbus writing is set on.
I am hoping to be able to set the charge timer and the dashboard clock somehow too. I'm sure I will have more questions once I get these things figured out, but in the meantime are there any suggestions that I can try to get the system working as I think it should?
Thanks in anticipation.
Paul.
moffetx
I'm not an expert but have a
I'm not an expert but have a 2018 40kWh env200 and through trial and error have got some things working so can offer some advice at least. I have the Accenta model which doesn't have the screen the Tekna has so may be slightly different - I know the Tekna drivers need to disconnect the TCU module but I assume this had been done if the head unit has been replaced.
The TPMS display will only display once it has been driven for a bit but after that will stay there (it's only live while driving though).
With waking up the vehicle I have the same experience.
I had the same issues with the aircon and locking/unlocking but managed to get it working (with a few caveats). Although the documentation says to always set the year to 2015 for any env200 I found I needed to set the year to 2016 - this is because it is in the code to send the command on a different can on 2016 models upwards and this is what got it working for me.
The aircon needs to be turned on when you shut down the vehicle in order for it to then work from the app. I don't know why this is but now I always leave it on the minimum blower on the windscreen even when I'm not using the heater or aircon because I kept forgetting to turn it on before getting out!
The locking and unlocking needs the can to be awake and this is done from the app by turning on the aircon (as you've noticed waking up the vehicle doesn't do this).
I can't help with the charge timer or dash clock but good luck in finding a solution.
PaulC
Thank you so much for this
Thank you so much for this suggestion, I had tried what I thought was everything, but changing the year to 2016 as you suggest has got me working!
In fact, everything you describe, such as having to wake the car with the aircon control if you want to use the locking and unlocking function is exactly the same for me. I imagine I have an identical setup.
I have not experimented with the charge functionality yet. And I do not yet understand how to set the target temperature, but I am so much further along this journey.
Thank you once again.
andyorkney
andyorkney's picture
Wish I'd found this earlier -
Wish I'd found this earlier - I had similar issues getting things to work. The set to 2015 to get climate control working was a BIG road block; so much so that I think the installation instruction need to be updated to be less assertive in respect of setting to 2015. Also as I think some clarity in respect of the Leaf ZE1 2018+ issues NOT relating to the ENV200 would also be helpful (I bought the cables for CAN tap but they're not needed for ENV200 2018 as I had convinced myself when could not get any CAN write activity other than relay clunks for the first few days). I might yet write an install for ENV200 inc V2 and V3 server instructions - so many pitfalls! All working now - just the script for start stop of charging to do/find, tips for that welcomed!
