7 posts / 0 new
jokergermany
Volkswagen Passat GTE (2017)
I think about using OMVS to connect my car to HomeAssistant/EVCC
I only found VW e-UP as supported.
How do I find out what would be supported with my car?
markwj
markwj's picture
Sorry, but if your specific car is not listed as supported then likely it would not work at all with OVMS. Every car is different, and requires specific support. We have tried to do some generic support with (XX track and OBDII generic), but that doesn't work very well with modern EVs.
jaripetteri
Tested yesterday that at
Tested yesterday that at least SoC info from HV battery can be reseived from same call on e-Golf and Passat GTE as on e-Up so it may be preatty similar other way too. I'm planing to build my own OVMS HW and test this more on e-Golf and Passat GTE. Currently having just small DIY esp32-c3 HW to play a gound.
fowi4hjte
How have you build with the
How have you build with the esp-idf 3.3 a working OVMS image for the esp32-c3 that is supported starting from esp-idf version 4.3 onwards?
jaripetteri
No just played with ESPHome
No just played with ESPHome CAN-BUS commands and pulled SoC from e-Golf from same way as on e-Up on OVMS. Same is working on Passat GTE but there is a long way to full e-Golf or Passat GTE support. I thought that there is more common but lets see. Read about e-Golf support is atleas tried to do based on e-Up but nothing on main branch. I'm now just learning to build development environment for OVMS. Looks really good so hope I can contribute on project.
jokergermany
anything new?
anything new?
marcel151
News? Willing to help
Hello, anything new regarding this type of car? Existing "Security & Service Plus" licenses are running out and you can't renew them. So VW is fading out support for pre-facelift Passat GTE. If you need help from my side, I am happy to help. I have a CANable 2.0 on hand if you need dumps. But I am a newbie regarding this. Unfortunately, my license is also expired. So I can't control the car from the app.
