10 posts / 0 new
rabbitev
rabbitev's picture
sending commands to a car
I am trying to figure out the options for sending commands to a vehicle, specifically door lock/unlock, without the native app.  that would allow me to integrate it into my app.
Is the best path to create my own v3 server, and send commands through that server?
thanks for any help...
markwj
markwj's picture
I would suggest you either
I would suggest you either use protocol v3 (MQTT), or the HTTP API to the existing servers:
https://docs.openvehicles.com/en/latest/protocol_httpapi/index.html
mdallaire
Looking at my mqtt server I
Looking at my mqtt server I see that my ovms is subscribed to /ovms/ovmsleaf/[vehiculeid]/client/+/command/+ and /ovms/ovmsleaf/[vehiculeid]/client/+/active.
I assume there is a way to send commands on the +/command/+ topic but I can't seem to find any documentation on the command format and syntax expected. Is it something that is ready to be used or is it there in preparation for future features?
I have a Leaf 2015 that I have integrated in home-assistant as sensors but I would also like to send some commands like start charge or HVAC from home-assistant via MQTT.
markwj
markwj's picture
There is an experimental
There is an experimental implementation of this in the current firmware.
The v3 code in the module firmware listens on <topic_prefix>/client/+/command/+. It is expecting client/<client>/command/<id> and the command itself in the payload.
The command is run, and the response returned in the payload of <topic_prefix>/client/<client>/response/<id>.
The overall design approach is to separate each connecting client into their own namespace (identified by unique <client>), and to allow each client to run multiple commands perhaps concurrently or pipelined (each command/response connected via unique <id> within each client namespace).
mdallaire
I am very excited to try this
I am very excited to try this. In my case I am trying to publish the following without success:
ovms/ovmsleaf/[vehiculeid]/client/mqtt-explorer-83dfce13/command/1
The raw payload is the following:
climatecontrol on
I am using the session client name of my current mqtt client (MQTT Explorer) but I assume I could use pretty much any string, such as "home-assistant" when I get to integrate further?
The <id> is just a number, incremental or not, for the specific command and it's result? If I just want to send the occasional climatecontrol on/off I could reuse the same ID?
Do I need to send something on the /client/<client>/active topic for OVMS to start listening to commands?
Am I wrong to assume that the behavior should be about the same as using the shell?
Sorry if this is a lot of questions at once.
markwj
markwj's picture
The prefix 'ovms/ovmsleaf/',
The prefix 'ovms/ovmsleaf/', seems strange, but so long as you are sure that matches the ovms config, it should be ok.
The client ID is up to you. So long as it is unique.
So long as the server v3 component is enabled, started and connected, it should pickup commands, and the commands themselves are simple shell commands.
Probably easiest to turn on debug logging for the server v3 component (log level verbose ovms-server-v3), and see what that shows.
mdallaire
ovmsleaf is the mqtt username
ovmsleaf is the mqtt username used to login to my mqtt server. It gets in the topic automatically.
I just got to testing this again and it worked perfectly this time, I was able to start and stop climate control and got the response to the command in MQTT. Is there anything you would like to be tested to help with the developpement of the v3 server? I am in the process of integrating this in my home-assistant, when I am satisfied with the results I will post some of the configs to help other people get going.
markwj
markwj's picture
A home assistant integration
A home assistant integration would be cool. Just not sure if that should be via MQTT (v3) or the v2 HTTP API.
schup011
I was also interested in
I was also interested in sending commands and
HERE IS THE ULTIMATE GUIDE
1) Find out the mqtt prefix by looking for messages in your mqtt server with <prefix>/metric/<suffix>. There should be a quite of them once the module is connected to the V3 server.
2) Having the <prefix>, your command looks like <prefix>/client/<vehicleID>/command/<whatyoulike>.
<vehicleID> is the unique ID you have given to your module.
<whatyoulike>: at least it seems to me that it doesn't matter what to put here. I put homelink because of other examples here, but something else did the same thing.
3) Having the command, now you can have different payloads. What I found is:
metrics
climatecontrol
charge
homelink
4) The great thing is:The module will always respond with <prefix>/client/<vehicleID>/response/<whatyoulike>. And it will explan the usage of one of the commands, if you put nothing else. E.g. if you put only
metrics
as payload, the module will respond:
Subcommand required
Usage: metrics list|persist|set|trace
And you can even get more help if you put one of the subcommands. If you put
metrics list
you get the whole lists of all metrics including their values.
5) FInd out your own usage, I will be using
charge start
charge stop
metrics set v.c.limit.soc 80 (or another number)
climatecontrol on
climatecontrol off
I would be happy if someone could post possible other commands, if you find more.
ENJOY!
schup011
Here is how to get the whole
Here is how to get the whole list of commands:
Just post ? as payload, then it responds (in my case, I have a Nissan Leaf):
.                    Run a script
bms                  BMS framework
boot                 BOOT framework
can                  CAN framework
cellular             CELLULAR MODEM framework
charge               Charging framework
climatecontrol       (De)Activate Climate Control
config               CONFIG framework
copen                CANopen framework
dbc                  DBC framework
disable              Leave secure mode (disable access to most commands)
echo                 Script utility: output text
egpio                EGPIO framework
enable               Enter secure mode (enable access to all commands)
event                EVENT framework
exit                 End console session
help                 Ask for help
homelink             Activate specified homelink button
location             LOCATION framework
lock                 Lock vehicle
log                  LOG framework
metrics              METRICS framework
module               MODULE framework
network              NETWORK framework
notify               NOTIFICATION framework
obdii                OBDII framework
ota                  OTA framework
plugin               PLUGIN framework
power                Power control
pushover             pushover notification framework
re                   RE framework
script               SCRIPT framework
sd                   SD CARD framework
server               OVMS Server Connection framework
sleep                Script utility: pause execution
stat                 Show vehicle status
store                STORE framework
test                 Test framework
time                 TIME framework
tls                  SSL/TLS Framework
tpms                 TPMS framework
unlock               Unlock vehicle
unvalet              Deactivate valet mode
valet                Activate valet mode
vehicle              Vehicle framework
vfs                  Virtual File System framework
wakeup               Wake up vehicle
wifi                 WIFI framework
xnl                  Nissan Leaf framework
