Ok I got my module, wifi only and have it setup per instructions. I can connect with my laptop and see it's connected when I go to status it tells me the 12 volt battery state and that's about all. When I click on the dashboard tab everything is showing 0's. Any suggestions.
I guess I didn't understand. When I plugged in my charger I do show traction battery voltage and % of charge. I guess I was expecting more information. Also unable to get anything from my iphone app. :(
hello, have you selected the right vehicle and turned on the ignition?
Didn't know about turning on the ignition. I thought I could monitor from my home while my car was parked outside with my iphone. didn't know it had to be turned on. I did select the right vehicle. so confused.
The module only displays the last data from the vehicle. Because the CAN bus sleeps and provides no information when the car is saved and ignition off.
If the loading process, current data will be delivered.
Some things are only read out if CanWrite is activated in the settings.
I think it's just too complicated for me. I read what you said and still a little confused. Even with the key on only thing I see is the 12 volt battery state. If I plug in my charger then I do see % charged and battery voltage. I thought there would be more data displayed so not sure what's going on.
What Vehicle you have and what Firmaware version you use?
I have a 2016 Smart Fortwo ED and I believe latest firmware 3.2.002/ota_0/main (build idf v3.2-dev-1420-g151269458 May 12 2019
On the "main" Firmware are only Basic Functions for the Smart. You should update to the "edge" developer Version. Under Firmware "Versions-Tag" add "edge" than under Flash From Web clear the Http-Url and click on Flash now. After Reboot aou should be on 3.2.002-150-gec54228 or higher.
Now you can set unter "Smart ED 3.Gen" -> Features "Enable CAN write(Poll)"
Thanks for the information but I can't actually figure out what your saying with where to add edge
https://dimitrie.eu/ovms-Firmware-1.PNG
Ok thanks. Got it and installed the new firmware but I seen no difference. With charger unplugged I am only still just seeing the 12 volt battery voltage. What am I missing.
You have a Smart ED 451 or Smart ED/EQ 453 model? the new on?
451 Now I see the menu for the smart. Maybe I am expecting more than is available. Withe the key on in the dashboard I see traction battery voltage and soc. In the status screen I do see my car mileage, range etc. Sorry for all the confusion but not as technical as probably most are doing this. Really just need to know if I am getting what I am supposed to. :)
One more question and then I will leave you alone. In the autostart setting what should it be, can 1 2 3 or nothing at all? Thanks for all the help.
You mean Start OBD2ECU? nothing
Yes so will set to nothing
