8 posts / 0 new
sbwithers
Anyone got OVMS working in Australia / NZ in an MG eZS?
I've been working on getting OVMS set up with my eZS. So far:
- Created accounts on openvhicles.com and ovsm.dexters-web.de. ​
- Created the same vehicle ID on both.
- Set the OVSM Module Wifi SSID and password succesfully and connected it to my home wifi. The module sees the OVSM v2 server on either OVSM server (so both work, if selected).
- Upgraded the firmware on the Module to the latest 'edge' build. I selected the "MG EV" as the model. Everything seems to be talking to everything.
- Installed the Android app on my phone. I set up the MG eZS as the car, with the correct Server (cloud) and Module passwords.
- The command shell on the Module (accessed view wifi) can see the phone app connecting and disconnecting. The log shows the Module sending and receiving information to the OVSM server in the cloud.
- installed a 16GB MicroSD and configured logging to the SDcard.
But no matter what, the module status and the app can't see anything in the car other than the 12v battery.
I'm wondering if the Australia / NZ eZS firmware is different......I'm getting nothing, despite all the required connections (Module to cloud, wifi, app, etc) clearly working.
Has anyone seen an HV battery % in the app or status reported with OVMS in an A/NZ eZS?
Pecari
Pecari's picture
this is the latest beta
this is the latest beta software
http://mafiles.mymgzsev.com:1978/ovms3test.bin
also follow this link below for more info and questions to Mike
https://discourse.mymgzsev.com/t/current-status-and-beta-builds-of-ovms-firmware/263/20
mvella42
Same experience with my Australian MG ZS EV
I have had a Nissan LEAF working fine with my OVMS module for many months, so I know I have the configuration correct.
I recently purchased an Australian MG ZS EV and have moved the OVMS module over to it today.
I have upgraded to the latest beta sotware (link just above), reconfigured for MG, restarted the OVMS, and like the OP, the OVMS can only see the 12v battery voltage, nothing else.
This seems to be whether charging or not.
My OVMS has an SD Card in it as well as SIM with working 3G service.
Very happy to help out with any logging/debug info that could assist.
Cheers,
Matt
speculatrix
speculatrix's picture
is the cable for the MG the
is the cable for the MG the same one as for the Leaf? I'm just pondering if there's different can buses that different cables will route to the OVMS module.
mvella42
OBD cable for LEAF vs MG
Good question.
I'm using the same cable that worked fine in the LEAF, so if they are different, that could explain it .....
Yep, looking at the Fasttech cables, it does seem the LEAF one has a different pinout to the standard one. That probably explains my problem, thank you :-)
I will order a standard cable and report back how it goes.
mvella42
Yes it's working for me too
MY problem was using the Nissan Leaf cable.
Like posted above, using the standard cable with OVMS works fine.
kostasoul
Web interface working
Have the right hand cable from fasttech and its working.
1441200 OBD-II to DB9 Data Cable for OVMS right
I'm using a build of the firmware from 1st Jan I found here
https://ovms.dexters-web.de/firmware/ota/v3.2/edge/ovms3.bin
Haven't setup the android app yet but I'll check those links you provided.
Edit: Android app now working as well.
speculatrix
Hi, try the discussion board
Hi, try the discussion board at https://discourse.mymgzsev.com/ for the latest activities
