Hello!
I've been using OVMS successfully for about a month now. Everything used to work great, but now somehow my modem does not connect to the internet anymore. I've checked the SIM in another device and it is working normally.
This is the output from the log. Any ideas?
W (672062) simcom: 3 minutes since last MUX rx frame - assume MUX has failed
I (672062) gsm-ppp: Shutdown (direct)
I (672062) gsm-nmea: Shutdown (direct)
I (672062) gsm-mux: Stop MUX
I (672062) simcom: Power Cycle
I (673062) simcom: State: Enter PoweringOn state
I (673062) simcom: Power Cycle
I (674062) netmanager: Set DNS#1 0.0.0.0
I (674072) netmanager: Set DNS#2 0.0.0.0
I (680072) simcom: State: Enter PoweredOn state
I (683322) simcom: SIM card PIN code required
I (683322) simcom: Using PIN code "3373"
I (700072) simcom: State: Enter MuxStart state
I (700072) gsm-mux: Start MUX
I (700082) gsm-mux: Channel #0 is open
I (700082) gsm-mux: Channel #1 is open
I (700092) gsm-mux: Channel #2 is open
I (700102) gsm-mux: Channel #3 is open
I (700102) gsm-mux: Channel #4 is open
I (701062) simcom: State: Enter NetWait state
I (701062) gsm-nmea: Startup
This keeps repeating...
Thank you very much!
Alex Lange
OVMS# module summary
OVMS MODULE SUMMARY
Module
Version: 3.2.015/ota_0/main (build idf v3.3.2-881-g22d636b7b Sep 2 2020 08:3 2:35)
Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1
12v: 0.0v
SIMCOM Modem Status
SIM card PIN code required.
Network Registration: NotRegistered
Provider:
Signal: -83 dBm
State: NetWait
Ticker: 44
User Data: 0
HW FIFO overflows: 0
Buffer overflows: 0
Mux
Status: up
Open Channels: 4
Framing Errors: 0
Last RX frame: 36 sec(s) ago
RX frames: 26
TX frames: 10
PPP: Not connected
GPS: Connected on channel: #1
Status: enabled
Time: enabled
Configuration
[auto]
dbc: no
egpio: no
ext12v: no
init: yes
modem: yes
obd2ecu:
scripting: yes
server.v2: yes
server.v3: no
vehicle.type: KN
wifi.mode: apclient
wifi.ssid.ap: OVMSKona
wifi.ssid.client: Yu
[can]
[dbc]
[egpio]
monitor.ports:
[http.plugin]
[http.server]
[locations]
[log]
[modem]
apn: pinternet.interkom.de
apn.password:
apn.user:
enable.gps: yes
enable.gpstime: yes
enable.net: yes
enable.sms: yes
pincode: 3373
[module]
cfgversion: 2020053100
init: done
[network]
dns:
[notify]
[obd2ecu]
[obd2ecu.map]
[ota]
server: ovms.dexters-web.de/firmware/ota
[password]
module: **redacted**
server.v2: **redacted**
[power]
[pushover]
[sdcard]
[server.v2]
tls: yes
[server.v3]
[ssh.info]
fingerprint: ARMFpemNhnfTxUn9Kt+5aRYnlI28PEpNFr8rmickEsQ
[ssh.keys]
[ssh.server]
key: **redacted**
[system.adc]
[tpms]
[usr]
[vehicle]
bms.alerts.enabled: no
units.distance: K
[wifi.ap]
OVMSKona: **redacted**
[wifi.ssid]
Yu: **redacted**
[xkn]
REPORT ENDS
Hmm, looks like this was some connection issue with the antenna. I've unplugged the modem board and checked the antenna connections, reassembled everything and it started right away again...
never mind :)
Same issue again
Looks like my GSM signal Quality has significantly degraded since the device was new. Already tried a different antenna and checked the internal connections. But I can barely get any connections.
Any suggestions?
stesso problema anche per me ed è il secondo modulo!
Try swapping the internal GPS / GSM antenna cables (so swap them on the modem board, and then swap the external antennas as well). That will tell you if there is some issue with the internal cables or their connections.
I've already tried this. It did not help. Also checked all connections with a multimeter and they seem OK.
I guess something is wrong with the modem board...
Any suggestions?
Otherwise I will try to get a refund. It is not working for me anymore.
I'd like to add that I have this same problem on my v3 module with the same software version (3.2.015). The modem worked for some months, and has randomly just stopped working.
my shell shows a continuous repeat of:
I (1241132) simcom: State timeout, transition to 2
I (1241132) simcom: State: Enter PoweringOn state
I (1241132) simcom: Power Cycle
I also note in the Status page I get this repeating:
[21:21:46]
system.modem.poweringon[21:21:46]
egpio.output.0.high[21:21:46]
egpio.output.0.lowFirmware: 3.2.015/ota_0/main (build idf v3.3.2-881-g22d636b Sep 2 2020 08:21:02) Running partition: ota_0 Boot partition: ota_0 Factory image: 3.2.002 OTA_O image: 3.2.015 OTA_1 image: 3.2.014
i have the exact same problem
and I too ((((
I have exact the same problem
I have the same issue
If connected to usb the modem starts.
Battery voltage checked and ok
Powermanagement disabled
Same issue connected to diffrent cars.
Module reset does not help
All help welcome
endless loop debug log
I (921284) simcom: State: Enter PoweringOn state
I (921284) simcom: Power Cycle
V (922294) simcom: tx: 41 54 0d 0a | AT..
D (922294) simcom: tx scmd ch=0 len=4 : AT
V (923284) simcom: tx: 41 54 0d 0a | AT..
D (923284) simcom: tx scmd ch=0 len=4 : AT
V (924284) simcom: tx: 41 54 0d 0a | AT..
D (924284) simcom: tx scmd ch=0 len=4 : AT
V (925284) simcom: tx: 41 54 0d 0a | AT..
D (925284) simcom: tx scmd ch=0 len=4 : AT
V (926284) simcom: tx: 41 54 0d 0a | AT..
D (926284) simcom: tx scmd ch=0 len=4 : AT
V (927284) simcom: tx: 41 54 0d 0a | AT..
D (927284) simcom: tx scmd ch=0 len=4 : AT
V (928284) simcom: tx: 41 54 0d 0a | AT..
D (928284) simcom: tx scmd ch=0 len=4 : AT
V (929284) simcom: tx: 41 54 0d 0a | AT..
D (929284) simcom: tx scmd ch=0 len=4 : AT
V (930284) simcom: tx: 41 54 0d 0a | AT..
D (930284) simcom: tx scmd ch=0 len=4 : AT
V (931284) simcom: tx: 41 54 0d 0a | AT..
D (931284) simcom: tx scmd ch=0 len=4 : AT
V (932284) simcom: tx: 41 54 0d 0a | AT..
D (932284) simcom: tx scmd ch=0 len=4 : AT
V (933284) simcom: tx: 41 54 0d 0a | AT..
D (933284) simcom: tx scmd ch=0 len=4 : AT
V (934284) simcom: tx: 41 54 0d 0a | AT..
D (934284) simcom: tx scmd ch=0 len=4 : AT
V (935284) simcom: tx: 41 54 0d 0a | AT..
D (935284) simcom: tx scmd ch=0 len=4 : AT
V (936284) simcom: tx: 41 54 0d 0a | AT..
D (936284) simcom: tx scmd ch=0 len=4 : AT
V (937284) simcom: tx: 41 54 0d 0a | AT..
D (937284) simcom: tx scmd ch=0 len=4 : AT
V (938284) simcom: tx: 41 54 0d 0a | AT..
D (938284) simcom: tx scmd ch=0 len=4 : AT
V (939284) simcom: tx: 41 54 0d 0a | AT..
D (939284) simcom: tx scmd ch=0 len=4 : AT
V (940284) simcom: tx: 41 54 0d 0a | AT..
D (940284) simcom: tx scmd ch=0 len=4 : AT
V (941284) simcom: tx: 41 54 0d 0a | AT..
D (941284) simcom: tx scmd ch=0 len=4 : AT
I (941284) simcom: State timeout, transition to 2
I (941284) simcom: State: Enter PoweringOn state
I (941284) simcom: Power Cycle
V (942294) simcom: tx: 41 54 0d 0a | AT..
D (942294) simcom: tx scmd ch=0 len=4 : AT
V (943284) simcom: tx: 41 54 0d 0a | AT..
D (943284) simcom: tx scmd ch=0 len=4 : AT
V (944284) simcom: tx: 41 54 0d 0a | AT..
D (944284) simcom: tx scmd ch=0 len=4 : AT
V (945284) simcom: tx: 41 54 0d 0a | AT..
D (945284) simcom: tx scmd ch=0 len=4 : AT
V (946284) simcom: tx: 41 54 0d 0a | AT..
D (946284) simcom: tx scmd ch=0 len=4 : AT
V (947284) simcom: tx: 41 54 0d 0a | AT..
D (947284) simcom: tx scmd ch=0 len=4 : AT
V (948284) simcom: tx: 41 54 0d 0a | AT..
D (948284) simcom: tx scmd ch=0 len=4 : AT
V (949284) simcom: tx: 41 54 0d 0a | AT..
D (949284) simcom: tx scmd ch=0 len=4 : AT
V (950284) simcom: tx: 41 54 0d 0a | AT..
D (950284) simcom: tx scmd ch=0 len=4 : AT
V (951284) simcom: tx: 41 54 0d 0a | AT..
D (951284) simcom: tx scmd ch=0 len=4 : AT
V (952284) simcom: tx: 41 54 0d 0a | AT..
D (952284) simcom: tx scmd ch=0 len=4 : AT
V (953284) simcom: tx: 41 54 0d 0a | AT..
D (953284) simcom: tx scmd ch=0 len=4 : AT
V (954284) simcom: tx: 41 54 0d 0a | AT..
D (954284) simcom: tx scmd ch=0 len=4 : AT
V (955284) simcom: tx: 41 54 0d 0a | AT..
D (955284) simcom: tx scmd ch=0 len=4 : AT
V (956284) simcom: tx: 41 54 0d 0a | AT..
D (956284) simcom: tx scmd ch=0 len=4 : AT
V (957284) simcom: tx: 41 54 0d 0a | AT..
D (957284) simcom: tx scmd ch=0 len=4 : AT
V (958284) simcom: tx: 41 54 0d 0a | AT..
D (958284) simcom: tx scmd ch=0 len=4 : AT
V (959284) simcom: tx: 41 54 0d 0a | AT..
D (959284) simcom: tx scmd ch=0 len=4 : AT
V (960284) simcom: tx: 41 54 0d 0a | AT..
D (960284) simcom: tx scmd ch=0 len=4 : AT
V (961284) simcom: tx: 41 54 0d 0a | AT..
D (961284) simcom: tx scmd ch=0 len=4 : AT
I (961284) simcom: State timeout, transition to 2
I (961284) simcom: State: Enter PoweringOn state
I (961284) simcom: Power Cycle
V (962294) simcom: tx: 41 54 0d 0a | AT..
D (962294) simcom: tx scmd ch=0 len=4 : AT
V (963284) simcom: tx: 41 54 0d 0a | AT..
D (963284) simcom: tx scmd ch=0 len=4 : AT
V (964284) simcom: tx: 41 54 0d 0a | AT..
D (964284) simcom: tx scmd ch=0 len=4 : AT
V (965284) simcom: tx: 41 54 0d 0a | AT..
D (965284) simcom: tx scmd ch=0 len=4 : AT
V (966284) simcom: tx: 41 54 0d 0a | AT..
D (966284) simcom: tx scmd ch=0 len=4 : AT
V (967284) simcom: tx: 41 54 0d 0a | AT..
D (967284) simcom: tx scmd ch=0 len=4 : AT
V (968284) simcom: tx: 41 54 0d 0a | AT..
D (968284) simcom: tx scmd ch=0 len=4 : AT
V (969284) simcom: tx: 41 54 0d 0a | AT..
D (969284) simcom: tx scmd ch=0 len=4 : AT
V (970284) simcom: tx: 41 54 0d 0a | AT..
D (970284) simcom: tx scmd ch=0 len=4 : AT
V (971284) simcom: tx: 41 54 0d 0a | AT..
D (971284) simcom: tx scmd ch=0 len=4 : AT
V (972284) simcom: tx: 41 54 0d 0a | AT..
D (972284) simcom: tx scmd ch=0 len=4 : AT
V (973284) simcom: tx: 41 54 0d 0a | AT..
D (973284) simcom: tx scmd ch=0 len=4 : AT
V (974284) simcom: tx: 41 54 0d 0a | AT..
D (974284) simcom: tx scmd ch=0 len=4 : AT
V (975284) simcom: tx: 41 54 0d 0a | AT..
D (975284) simcom: tx scmd ch=0 len=4 : AT
V (976284) simcom: tx: 41 54 0d 0a | AT..
D (976284) simcom: tx scmd ch=0 len=4 : AT
V (977284) simcom: tx: 41 54 0d 0a | AT..
D (977284) simcom: tx scmd ch=0 len=4 : AT
V (978284) simcom: tx: 41 54 0d 0a | AT..
D (978284) simcom: tx scmd ch=0 len=4 : AT
V (979284) simcom: tx: 41 54 0d 0a | AT..
D (979284) simcom: tx scmd ch=0 len=4 : AT
V (980284) simcom: tx: 41 54 0d 0a | AT..
D (980284) simcom: tx scmd ch=0 len=4 : AT
V (981284) simcom: tx: 41 54 0d 0a | AT..
D (981284) simcom: tx scmd ch=0 len=4 : AT
I (981284) simcom: State timeout, transition to 2
I (981284) simcom: State: Enter PoweringOn state
I (981284) simcom: Power Cycle
V (982294) simcom: tx: 41 54 0d 0a | AT..
D (982294) simcom: tx scmd ch=0 len=4 : AT
V (983284) simcom: tx: 41 54 0d 0a | AT..
D (983284) simcom: tx scmd ch=0 len=4 : AT
V (984284) simcom: tx: 41 54 0d 0a | AT..
D (984284) simcom: tx scmd ch=0 len=4 : AT
V (985284) simcom: tx: 41 54 0d 0a | AT..
D (985284) simcom: tx scmd ch=0 len=4 : AT
V (986284) simcom: tx: 41 54 0d 0a | AT..
D (986284) simcom: tx scmd ch=0 len=4 : AT
V (987284) simcom: tx: 41 54 0d 0a | AT..
D (987284) simcom: tx scmd ch=0 len=4 : AT
V (988284) simcom: tx: 41 54 0d 0a | AT..
D (988284) simcom: tx scmd ch=0 len=4 : AT
V (989284) simcom: tx: 41 54 0d 0a | AT..
D (989284) simcom: tx scmd ch=0 len=4 : AT
V (990284) simcom: tx: 41 54 0d 0a | AT..
D (990284) simcom: tx scmd ch=0 len=4 : AT
V (991284) simcom: tx: 41 54 0d 0a | AT..
D (991284) simcom: tx scmd ch=0 len=4 : AT
V (992284) simcom: tx: 41 54 0d 0a | AT..
D (992284) simcom: tx scmd ch=0 len=4 : AT
V (993284) simcom: tx: 41 54 0d 0a | AT..
D (993284) simcom: tx scmd ch=0 len=4 : AT
V (994284) simcom: tx: 41 54 0d 0a | AT..
D (994284) simcom: tx scmd ch=0 len=4 : AT
V (995284) simcom: tx: 41 54 0d 0a | AT..
D (995284) simcom: tx scmd ch=0 len=4 : AT
V (996284) simcom: tx: 41 54 0d 0a | AT..
D (996284) simcom: tx scmd ch=0 len=4 : AT
V (997284) simcom: tx: 41 54 0d 0a | AT..
D (997284) simcom: tx scmd ch=0 len=4 : AT
V (998284) simcom: tx: 41 54 0d 0a | AT..
D (998284) simcom: tx scmd ch=0 len=4 : AT
V (999284) simcom: tx: 41 54 0d 0a | AT..
D (999284) simcom: tx scmd ch=0 len=4 : AT
V (1000284) simcom: tx: 41 54 0d 0a | AT..
D (1000284) simcom: tx scmd ch=0 len=4 : AT
V (1001284) simcom: tx: 41 54 0d 0a | AT..
D (1001284) simcom: tx scmd ch=0 len=4 : AT
I (1001284) simcom: State timeout, transition to 2
I (1001284) simcom: State: Enter PoweringOn state
I (1001284) simcom: Power Cycle
V (1002294) simcom: tx: 41 54 0d 0a | AT..
D (1002294) simcom: tx scmd ch=0 len=4 : AT
V (1003284) simcom: tx: 41 54 0d 0a | AT..
D (1003284) simcom: tx scmd ch=0 len=4 : AT
V (1004284) simcom: tx: 41 54 0d 0a | AT..
D (1004284) simcom: tx scmd ch=0 len=4 : AT
V (1005284) simcom: tx: 41 54 0d 0a | AT..
D (1005284) simcom: tx scmd ch=0 len=4 : AT
Do you use hologram? About May my modem stopped working. I fiddled with it a bunch then finally put in a support call with hologram. They did a "SIM refresh" and it started working again.
If I use the microusb connector the modem starts working so it must be a power issue and not simcard related.
Allready did a full reset bu that does noet fix the problem.
